Hi
Please i need to know how link some Powerlogic PM500 in serie by means of RS232 to PC. Please send Diagram connection. I have Software SCADA
AFCOM P-CIM 7.00 in order to make this work.
Thank you
Thank you
As far as I can tell, the PM500 only has the option for rs485 modbus comms. So unless you have some sort of modbus interface then you have a problem. Check out the manual online for more info. (do a google search for pm500.)
Hello, I need to know if you find the answer to this questions and have now the interface use by the PM500. (If this is possible please give me this information.)
hi. have you find the answer? If yes, please share your information. By the way, thx.
I have a bit similarity problem with you. I am studying how to get data from a PM500. There are many RS485 to RS232 converter. I want to write a simple C++ program and use a pc to run for communication.
Thank you...
<my email: tjansaut@growthsteel.com>
Thank you...
Please send all details to orlyi@afcon-inc.com
The technical support in AFCON will help you!
He hadn't a single redeeming vice.
-- Oscar Wilde
