Which kind of Zelio connection are you refering to? (modbus, ...).
Did you check the Zelio section of http://www.telemecanique.com?
If not already done, click: http://www.telemecanique.com/en/functions_discovery/function_5_10.htm and select Zelio logic, then click the library green button and you'll access the available documentation.
hope it helps...
jm
hope it helps...
jm
Honk if you hate bumper stickers that say "Honk if ..."
