ModbusTCP with PHP
Programming languages. topic
Posted by Fabou3377 on 15 November, 2006 - 11:47 pm
I need to find a resource to interface php with modbus/TCP, Is there anybody know a resource?
Posted by Ganesh Okade on 21 November, 2006 - 10:21 pm
Could you tell if your platform is Windows or Linux? If Windows, then there is a way to interface a dll into a PHP script. You can find many implementations of MODBUS in the form of a dll from various vendors.
If Linux, I am not too sure at the moment. Thanks.
Ganesh Okade
Sunlux Technologies Ltd.
http://www.sunlux-india.com
Posted by Michael Griffin on 26 November, 2006 - 1:49 pm
There are free modbus/TCP drivers available. I will let others recommend particular libraries, but you can perhaps use the ones from pvbrowser (http://pvbrowser.de) or MAT (http://sourceforge.net/projects/mat/).
In either case, you will end up with a C library that you need to interface to PHP. Below are some URLs which show how to do this in the general case.
http://www.php.net/manual/en/zend.creating.php
http://www.zend.com/php/internals/index.php
Posted by Yan Seiner on 27 November, 2006 - 11:28 pm
I've got a fairly generic modbus library written in C for linux at
http://www.seiner.com/ts7000/index.php/Modbus_and_Serial_Comm
It's GPL, so please read and understand the benefits and restrictions that places on the code use.
I am working on a TCP wrapper now; if anyone would like to contribute, please feel free.
Mostly it needs testing and debugging.
--Yan
Posted by Roy Yin on 10 March, 2007 - 3:56 pm
I have a program called Modserver on Linux (Fedora, Suse). It is very reliable.
The whole system structure
PHP
Modservre
SCADA, PLC
http://www.icscada.ca
Posted by Michael Griffin on 11 March, 2007 - 6:01 pm
In reply to Roy Yin: I had a look at your web site as I was curious, and noticed your mention of "XML Modbus protocol", "XML Modbus command", and "XML Modbus message". Is this just your way of describing an implementation of a set of web services, or is there actually some formal "XML Modbus" standard that I haven't heard of?
Posted by Roy Yin on 13 March, 2007 - 10:40 pm
Modserver is a service program, just like OPC server. To control a RTU, C, PHP, or any script language connect to Modserver by using TCP socket or Unix Socket, and send XML format command to Modserver. Modserver parses the XML command, optimizes , creates a RTU acceptable Modbus command, and sends to RTU. It will format the response from RTU to readable XML format, and send back.
To write 25.4 register 40179 on slave 15
<modbus tranid="1"
unitid="15"
address="40179"
number="2"
function="16"
datatype="float"
byteorder="DCBA"
data="25.4" />
and response:
<modbus tranid="1" function="16" data="" state="0" />
The Abrams' Principle:
The shortest distance between two points is off the wall.
