Y
The end of message, transmitted over serial line, can be detected with 3.5t pause. Why is it needed to detect 1.5t pause?
If pause is longer 3.5t - then OK, the frame is received, checking. If not completed - CRC will show it. If pause is shorter 3.5t and char is incoming - OK, just next char. What is the purpose of the 1.5t pause? What can be wrong if I take char between 1.5t and 3.5t?
