Modbus Links
Jump to a Date
modbus.control.com/rss/
Is there a driver available within the Siemens WinCC HMI package for communication to a Modicon Momentum PLC using MODBUS interface?
I tried, but I have the same problem. If anybody finds a solution, please email to me: albertras at gmail. com
Thanks,
Al
Thanks,
Al
WinCC version 5.1 does support modbus master driver. I am not sure about the later versions of it. You can use this driver for communication with any PLC which is supporting modbus.
Satish Bhat
Satish Bhat
