Modbus Links
Jump to a Date
modbus.control.com/rss/
I am looking for a modbus simulator that will be able to read extended registers. The modbus systems I work with are serial links as well as over ethernet. I need to test as a slave and as a master. Any tips or thoughts on this? I currently use the Calta modbus simulator, but have not figured out how to read the extended ranges, if it is even possible. Thank you for any information you can provide.
<I am looking for a modbus simulator that will be able to read extended registers.>
The Simply Modbus simulators will work. www.simplymodbus.ca
Automated Solutions Modbus Master and Slave products support 0-65535 registers.
http://automatedsolutions.com/products/modbusrtu.asp
http://automatedsolutions.com/products/modbustcp.asp
http: //automatedsolutions.com/products/modbusslave.asp
Fully functioning 30-day trials are available for download.
The Calta "Mdbus" simulator will allow retrieval of 65535 registers for each data type.
Lorne
Lorne
