member
passwd
remember me on
this computer.
- join now -
Jump to a Date
Select a topic of interest:
...and press:
RSS feed Use this link to get an RSS feed of the Modbus Community article flow, for private, non-commercial use only:
modbus.control.com/rss/
from the Application Engr department...
Modbus Register Writing
Software, including programming, OS issues, etc. topic
Posted by Amol on 5 January, 2009 - 5:56 am
I am working on ABB SCADA and I have to communicate to an instrument with it. Primarily the address was the problem but I used HR followed by the number which I got through modscan for the particular registers and it worked. I can read the data on my software.
However, I have to write some registers too (holding type). In SCADA there are only two things:
1. Take input field to write the data
2. Define that tag as controllable in software.
I tried it but it's not working. Does someone know how to write it?
Posted by Bari on 20 February, 2009 - 5:33 pm
Could you give me some directions on what code did you used in place of the HR? 4000?
I'm asking because I need to send tags from a Max 1000 DCS to a Scada.
I will appreciate your helps,
thanks,
Bari.
