Can I connect two masters for one slave modbus tcp?
Equipment Phoenix ILC150 ETH
Assuming the slave will allow more than one connection, which most allow, yes.
There is normally a maximum concurrent connection count for a slave but is it normally more than 2.
Good luck,
Mark
http://www.peakhmi.com/
Good luck,
Mark
It depends on the slave, but probably yes you can.
Each Modbus conversation requires a separate TCP connection to the Modbus slave. If the Modbus slave can accept multiple simultaneous connections then yes, it can be accessed simultaneously by multiple masters.
You might also get away with a single connection if each master opens and closes its connection for every Modbus transaction. Some masters do this. Others hold their connection open.
Yes. As long as the slave will support multiple simultaneous sockets (which it should).
The trouble with a kitten is that
When it grows up, it's always a cat
-- Ogden Nash.
