from the Forum department...
Communication between GC & DCS
Local and wide area networking in factory automation. topic
Posted by Hemant Rathod on 10 March, 2010 - 6:11 am
How to communicate between Yokogawa GC 1000 and DCS ? Proto- RS 485 modbus.
Communication through Fiber optic cables and it should be redundant.
Please advice the skim and send your comments
Thank you.
Posted by vmkaranth on 10 March, 2010 - 10:52 am
please mention which dcs you are using.
further as GC can share only calculated data and not the actual peaks for which you may have to use gcmaint software
Posted by Hemant on 11 March, 2010 - 12:57 am
DCS is from Invensys, please advice complete solution with gcmain software also
A continuing flow of paper is sufficient to continue the flow of paper.
-- Dyer
