How important is the parity "bit" during communication?
I have a firmware that supports RS-485 communication, and I have usually used an USB-TO-RS485 Adaptor to communicate from the PC to the device.
The default configuration has always been 9600 baud with 8bits, 1 stop bit, and no parity.
Modbus over serial-line v1.02 talks about parity MUST be "even" is RTU mode and 'no' parity as preferable on page 12.
The next line the spec says "devices may accept all different parity's (odd, even,none).
On most serial communications I have seen the default is always "NO PARITY". Do customers/developers/EMS care about 'even' parity?
Please share your experience.
