I am trying to setup a communication between the Endress Promag 53 flowmeter and a Unitronics PLC. The main problem is that I can't get the Endress alive. I have tried also with a connection Endress-Laptop via USB-RS485 converter and the CAS Scanner cannot locate the instrument. Does anyone have experience with the Endress Hauser flowmeter and its Modbus RTU 485 communication?
Thank you
Thank you
