R
I work with MODBUS devices and I would love to find a software like mbmasterv15.exe (RTU terminal working on DOS environment) capable of setting the parity bit and the stop bit.
https://drive.google.com/folderview...45UlgzbkN2bi16NEt1U2xYWHpISDc1RHc&usp=sharing
As you can see in the link I made a bat file which is intended to scan every address in the BUS in order to find a device with address I don't know in theory, my goal is to made scans with
Another solution for finding a "lost device" in the 256 possible addresses changing the parity bit and the Stop bit in windows will be nice.
Any kind of support or suggestion will be welcomed.
Thanks!
Thanks!
