Communicating with Citect and Twido using Modbus RTU
K
kishore
Need help in communicating Twido PLC with Citect-scada using Modbus-RTU. Couldn't get any proper documentation.
Please provide any documentation links if possible.
The absence of an answer in two weeks should be a sign that there probably isn't any cookbook recipe for the task you've got.
There is a 28 page document (it looks like the Modbus chapter from a manual) here:
http://www2.schneider-electric.com/...00/FA159970/en_US/Twido Modbus Addressing.pdf
It seems to be a reasonable description of Twido as both a Modbus master and slave, their example uses two Twidos's talking to one another, one as a master, the other as a slave.
You'll have to locate Citect Modbus documentation and read through it and then figure which is master/client, which is slave/server and start modifying the example to fit Citect/Twido.
You might consider documenting your step-by-step activities to getting Modbus talking and publishing it here as a Twido/Citect cookbook example.
